how to maintain the resolution of vi in programatically using labview 8.0
Hi friends,
 Using Labview 8.0 i created an exe of  application. every vis i set  the  vi properties just like the attachment below. after installing the exe in a higher resolution monitor, when i open a  sub window - 1st time its coming correctly but after stoping that sub window , if i open that sub window once again than the resolution(size of the vi) of the window is changing.
in my application i want to take the print out of that window , 1st time print out is coming correctly but due to this resolution problem next time it taking 2 pages for printing.
please help me for that.
Nikhil
(2,770 Views)
My first thought would be to remove the "Scale all objects ... " vi property.  I have been using LabVIEW for 10+ years, and I always found that function to work very poorly.  I never use it.  At least you could try removing that setting and see if your problem goes away.
http://www.medicollector.com
(2,374 Views)
