how to make LED flashing
i want to make flashing LED. how to do that?
Asif
Message 1 of 8
(9,963 Views)
Hi Asif,
set the blinking property of a LED indicator as needed…
Or switch it's value (TRUE/FALSE) periodically!
Message 2 of 8
(9,956 Views)
Hello Aisf138,
As GerdW says, you can use a While Loop to change the value of the LED (True/False) for each iteration using Shift Registers. In Addition, you can add a Wait function to control the "Blinking Time". I share with you a VI Snippet to do this app.
Regards!!!
Sebastian.
Message 3 of 8
(9,908 Views)
Any details? NI is dealing with many kinds of flashing LEDs including
Semiconductor manufacture control to make LEDs that can flash.
Controlling NI and 3-d party current sources to flash LEDs
Design of PCB to make LED driver to flash LEDs
Ethernet hubs flash active LED when transmitting data, if you write network communication, you have flashing LEDs
Above 2 software solutions
ETC...
Message 4 of 8
(9,881 Views)
Thanks Dear
its working. but i want to to start blinking by logic (0 or 1) just say by toggle switch.
how to do that.
Asif
Message 5 of 8
(9,858 Views)
I want one Boolean indicator (LED) to blink when i press toggle switch. i actually want to blink it when logic 1 on any input bit of PLC high.
Asif
Message 6 of 8
(9,856 Views)
Hi Asif,
Use the blinking property of the LED indicator, just connect your switch…
Read "any input bit" of your PLC, OR those bits, wire the result to the blinking property of your LED indicator…
Message 7 of 8
(9,846 Views)
Hi Asif138,
This VI Snippet makes a blinking Led when you press toogle switch using Event Structures and Property Nodes.
Regard!!!
Sebastian.
Message 8 of 8
(9,822 Views)
