how to make a 2d intensity plot?
I'm trying to make an intensity plot as a function of x and y positions.... I have a scanning stage that gives me the positions and I am measuring the intensities at those locations... I have put this on a 3d plot and it comes out nice, however, I need it on an intensity plot with multiple colors.... when trying to do this, I get time on one axis... I was wondering how I could change the axis to x and y for the intensity plot... thanks
(3,681 Views)
Have you tried transposing the 2d array?
With a picture I would be ale to see what you are trying to do better.
Beaton
- there is always an easy way, but it is always the hardest to find
(3,670 Views)
Hi there,
Are you referring to doing a projection of your 3D graph? There is a good shipping example, called 3D Surface Example - Fluctuating Sine Wave.vi which illustrates how to accomplish projection with a 3D graph.
Please post a picture or describe a little better what you're trying to do and we'll try to help you out!
-Sam F, DAQ Marketing Manager
(3,650 Views)
So, right now I'm using the 3d surface plot.  However, I wish it could look more like a 2d projection with different colors indicating the level of intensity such as:
http://www.capra.group.shef.ac.uk/3/Fig06ResistivityPlot.png
I was wondering how I can make this...  once again, the arguments I have are an x position and a y position that go through a raster scan via for loops, all while acquiring an intensity count at each x-y position.  Thanks.
(3,609 Views)
Have you tried a set up like this
but instead of random numbers you put in your 2d data
(3,599 Views)
