how to make a command automatically sending
can you explain me with a VI
Message 11 of 26
(1,456 Views)
Explain what? Boolean logic or shift registers? Shift registers are explained in the LabVIEW Help and should be in the tutorials. Have you done those? Examples on shift registers are also shipped with LabVIEW. Open the Example Finder (Help -> Find Examples) and search for "shift". You will find several, such as "Calculate Running Average" and "Find Maximum Value From Array".
Message 12 of 26
(1,443 Views)
I do not konw how to connect the shift register with the dispense structure
Message 13 of 26
(1,437 Views)
What have you tried?
Message 14 of 26
(1,428 Views)
I tried to use the shift register connect to the dispense case structure but i do not konw how to connect with output
Message 15 of 26
(1,416 Views)
The shift register is not for storing the total number of dispenses. It's for storing how many you've done. You wire a constant of zero to the left shift register so when your program starts you start off with nothing having been dispensed. Each time you dispense you increase the count. You check agains the state of the switch AND the current number of dispenses to determine if you can continue to dispense. This is really not that difficult. Instead of trying it with your real VIs, try it with simulated code.
Message 16 of 26
(1,401 Views)
Hi
  i have done what you said but it doee not work can you tell me how to design it with my VI, i am really stuck on it
Message 17 of 26
(1,370 Views)
Please attach your VI so  we can see what you are doing and explain what is wrong and how to fix it.  The best way to learn LabVIEW is for you to try to do it yourself then ask for help when things go wrong rather than having people tell you how to do it.
Message 18 of 26
(1,360 Views)
Hi
 i have tried use your suggestion, but the disgram is wrong can you check it for me?
Message 19 of 26
(1,316 Views)
You need to provide the missing VI's. There are three of them.  They are the sub-vi's within the one you provided.
Message 20 of 26
(1,302 Views)
