how to make a communication of two VIs from difference computers throught VI server?
I have built the program which is attached at below. But it doesn't work. Can any one help me?
(2,366 Views)
Hi Barry,
What do you mean "it doesn't work"? What kind of errors are you seeing? Also, you only specified the file name (data.vi) when opening a VI reference. Try specifying the whole path to the VI. Also, you might want to make sure you are able to ping your other computer from the start (to see if this is a LabVIEW issue or a network issue).
Hope this helps,
Travis H.
LabVIEW R&D
(2,347 Views)
hi Travis H,
I have dealed with that problem.Thanks for your help.
(2,325 Views)
