how to make a pulse train on DO line useing E-series in LV7
Im trying to make a finite TTL pulse train that I would like to put on DO-0. Ive gone over some of the VIs that have came with the program but none of them seem to do this. I dont need a starting trigger or anyhting like that. All i really need to get going is to make about a finite 1-3Khz TTL pulse width on my Digital out. Thanks a lot!
(2,536 Views)
LV7 has several example VI's on how to produce a pulse train. If you are using an E series card, then you should use the GPCTR output for your application.
I am using an E-Series Card to generate finite pulses and it works fine on the CTR output.
Have a look at "Finite Pulse Train (DAQ-STC).vi" in your Example Finder.
(2,536 Views)
