how to make a remote panel file dialog open remote directory from any computer
Hello to everybody. I am using Labview 6.1 and I would like to know how to make a remote panel file dialog open remote directory from any computer (Not only from a specific computer. If I open the file with a specific computer, I have to conect the path of the remote machine, but if I don´t know which remote computer is going to run the aplication, how can I do it?)?
(2,609 Views)
Hi!
first you have to know progammatically the name of the remote pc connected to your server: this is a problem!
I did not find a straigth way, LV 6.1 doesn't allow much progammatic control on the remote panel connection feature, but I'm confident that in the next LV version this will be improved!
The point is that the Remote Panel Connection Manager (from the Tools menu) has all the informations about the connection: client name, server vi and whatever.
This application is embedded in the \PROJECT\REMOTEPANEL.LLB and consists of a set of password protected vis.
So here's the trick: use VIServer to grab data from the rpcm Get Server Data.vi when the Remote Panel Connection Manager is in run mode. By this you get all the informations (not only client name)o
f the remote panel connection. See my example.
By the way use client machine name to build the file dialog function input path.
If anybody has an alternative method it would be more than appreciated to share it.
Good luck,
Alberto Locatelli
(2,609 Views)
