how to make droppable area for images
Hi All
I would like to make one match the following using labview. For that i am using images , i will to drag images to droppable area and if the choice is correct i have to show "successfull" messege to student. please share your valuable points on it.
(3,089 Views)
I know that LabVIEW supports drag-and-drop, but to tell the truth have never used it. Where are you wanting to drag the image from? Another program? the desktop?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,085 Views)
Hi  Mike
Thanks a lot. What i need is i have an image name as "S" i have a droppable area name as "V". If i drop S on V i have to show messege " Successfull" . That means i have to check is S is dropping or not. If i drop image name as "X" then it must show messege "False". if you still need more help please ask me.
(3,070 Views)
Did you understand the previous question?:
Maybe you want to drag&drop files from Windows Explorer?
Did you try to use the forum's search or google? There are lots of info and examples how to do this:
http://lmgtfy.com/?q=labview+drag+and+drop+files
For example: http://digital.ni.com/public.nsf/allkb/81D867F8C6A1376D86257347001BE936
(3,053 Views)
