how to make excel format report uneditable directly through code
Dear sir,
 in my application i have given option to save product report in Excel format to the Harddisk.
It saves report in Excel format. I want this report passward protected for editing. Nobody should edit containt of report
without password, he should only able to see the report saved in Excel format.
    Please tell me how i can do above with labview software.
  I m waiting for reply
regard
Rajendra
(4,348 Views)
Hello gaikwadre,
Here is a VI that should do what you want to do.  I used the Report Generation toolkit.  At the save report.vi I added a password.  The person can look at the file in a read only, but can't make changes with out the password.  Please let me know if this works.
(4,336 Views)
thanks you!
i got my solution.
regards
rajendra
(4,324 Views)
Dear sir,
I want to access and edit the table of database(.mdb) file through Labview and it should save.
please tell me how i can do it.
i am waiting for reply.
regards
Rajendra
(4,317 Views)
Hello Rajendra,
There are a few ways you can open and edit an Access database.  This link describes those methods and provides a simple example.  The easiest way to do this is to use the Database Connectivity Toolkit.
Clint Meyer
(4,304 Views)
Connecting to Access (Jet actually) through LabVIEW is very easy and doesn't require the purchase of anything. See the code attached to this message. It includes drivers for connecting to a database, documentation on the drivers and a description of the basics of database utilization - using Access as the test case.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,283 Views)
