how to make final (read-only) version of a *.vi
... so that the *.vi is only runable but not editable...
Message 1 of 9
(3,901 Views)
You can password protect the diagram. Look under "VI properties...Security". 🙂
(Of course you can also e.g. remove the diagram, but then the VI can no longer be ugraded to a newer version)
If you have LabVIEW professional or higher (or purchased the application builder seperately), you can also turn your VIs into a standalone application. This has the advantage that you can run it on computers that don't have LabVIEW installed.
Message Edited by altenbach on 07-24-2006 11:01 PM
Message 2 of 9
(3,894 Views)
Hi Johan
To complete altenbachs point (what is very rarely, as he gives almost perfect answers most of the time), if you build a standalone application you do not need LV to be installed but the runtime engine. Additionally you can create an installer where the rte is included or it is downloadable (I think for free) from NI.
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 3 of 9
(3,890 Views)
I have Labview 8 Full development system... Does it include theese functions?
Message 4 of 9
(3,888 Views)
becktho wrote:
...Additionally you can create an installer where the rte is included or it is downloadable (I think for free) from NI.
Thanks! Yes, the runtime engine is a free download. The recents versions are quite large, so I usually don't include the runtime with the installer to keep the distribution small.
(The runtime version must match the LabVIEW version used to built the executable. However, you can install as many runtime versions as you need. If the correct runtime version is not installed, it will let you know what version it needs). 😄
Message 5 of 9
(3,880 Views)
No, FDS does not include the application builder. You can however purchase it as an add-on .
(Look for the section "deployment tools" in the comparison matrix ).
(Of course FDS includes the other mentioned options, such as passwording the diagram). 😄
Message 6 of 9
(3,876 Views)
Ok, then I know what to do... password.. Smiley Wink
Great help by the way!
Message 7 of 9
(3,867 Views)
"altenbach" <x@no.email> wrote in message news:1153809612639-395640@exchange.ni.com...
Thanks! Yes, the runtime engine is a <a href="http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BBB002C130D?opendocument&amp;node=132070_US" target="_blank">free download</a>. The recents versions are quite large, so I usually don't include&nbsp;the runtime&nbsp;with the installer to keep the distribution small.
(The runtime&nbsp;version&nbsp;must match the LabVIEW version used to built the executable. However, you can install as many runtime versions as you need. If the correct runtime version is not installed, it will let you know what version it needs). 😄
You don't even have to build a standalone executable to run it on a machine without LabVIEW.
If the runtime engine is present, you can also run (but not edit) normal VI's. Could save you the professional license.
Wiebe.
Message 8 of 9
(3,862 Views)
You can also use the VI property Exec.RunOnOpen. If this property is True, your VI is in run mode whenever you open it.
Message 9 of 9
(3,855 Views)
