how to make my labview codings as a package for labview
Hello NI,
                 I made drivers for some thrid party instruments, which is compatable for serial port and Ethernet. I have several vi's for that i cant able to share these vi's to my friends.
i just want to build one package of my driver, also i want to install these package to labview user library.
Tell me some good suggestion for this.
With warm regards,
Balaji DP
Application Engineer,
Gantner Instruments.
Balaji DP
Message 1 of 8
(3,011 Views)
The easiest way is to do a development distribution (File>>Save As.
If your needs are more complex, you can also try VIPM. I don't think the free version can do this, but it's worth it just for getting the OpenG code.
___________________
Try to take over the world!
Message 2 of 8
(3,003 Views)
where i can find this development distribution ? is there option available in labview?
Balaji DP
Message 3 of 8
(2,999 Views)
If you re using LV versions > 7.x, you can create an LLB by using the option Save As... in the Files menu.
You have to just open the top-level VI of that driver (or something) & go on to build the LLB. All other VIs will get added/bundled into it automatically. Smiley Happy
- Partha ( CLD until Oct 2027 🙂 )
Message 4 of 8
(2,993 Views)
In LV 7.x, I think it ll be under the Tools >> Build Source Distribution menu...
Message 5 of 8
(2,986 Views)
@Balaji_DP@yahoo.com wrote:
Hello NI,
With warm regards,
Balaji DP
Hi Balaji,
As tst mentioned, VI Package Manager will allow you to easily package your VIs for installing into LabVIEW, so that you can share them with your colleagues and friends.  The package building capability is scheduled for our next release.  You can find out more information here.
And, to answer tst's question, package building will be available in both the free Community version and the paid Professional version.
If you are interested in getting an early look and helping us test this next release, check out our VI Package Manager 2.0 Alpha Program announcement.
Best Regards,
-Jim
Message 6 of 8
(2,958 Views)
when will you going to release this option along with which version?. because i am going to purchase labview core package....
otherewise,  can i upgrade with existing version?
Balaji DP
Message 7 of 8
(2,941 Views)
VI Package Manager is a 3rd party add-on offered by JKI -- it's doesn't come with any LabVIEW version.
Message 8 of 8
(2,939 Views)
