how to make my waveform from excel file perodic in labview graph
Hi guys,
Previously I've made a vi which integrates the excel file, to plot the graph values in labview using the values in the excel file to give the me a better flexibility to decide what waveform i want it to be. Can i know how to actually make the graph periodic, as in the waveform repeats,  because currently it can just plot out the waveform accordingly to the values i inserted in the excel. I've attached my vi and aso my csv file together. Thanks guy.
(2,705 Views)
So do you want to read the same values over again?
If that is what you wish to achieve then use waveform chart as opposed to waveform graph. I editted your code slightly so that you can see the different.
I hope this helps!
Mehak D.
(2,678 Views)
