LabVIEW itself is an active-X server and is registered in the system.
The type library LabVIEW.tlb is in the folder resource of your installation.
If you want to run a VI you need LabVIEW or an application build from LabVIEW. You need the correct type library to get access to the methods and propertys.
To use active-X servers they need to be registered by the system. LabVIEW applications do this automatically at startup.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
