07-08-2011 01:59 AM
I am also a beginner in labview but it seems to me that Kyle has already ansered your question.
W.R.T logging data automatically, functions pallete>programming> file i/o> write to spreadsheet/measurement file.
07-08-2011 10:53 AM
You should try using the "Write to Measurement File" function to save your data. This function can be found in the File I/O palette. For the file type, if you pick "TDMS" you will be able to open this data in Excel using the TDM Add-in. I hope this helps!
