how to make write protect for Excel
Hi all
I need a clarification from you all
I am exporting my data's to Excel sheet and saving it in the hard disk.
I need to protect the sheet with password for opening the sheet
Kindly can anyone help me in this
Regards
Bala
(4,203 Views)
Have a look at the image below to password protect your workbook:
Make sure that you close all the references to Excel. Each refnum wire needs to end either in an indicator if it is going to be a sub VI, or an Automation close if the VI is not a subVI.
Message Edited by JoeLabView on 06-24-2008 12:33 PM
(4,190 Views)
Here is the example if you want to protect individual sheets:
I didn't do these examples..  So ignore the string of question marks, it should have been a boolean indicator..
Saving will be similar.  Just look for the SAVE property within the property node selection.
RayR
(4,187 Views)
