how to measure RPM using digital I/O
Please check the code I have saved in LabVIEW 2009.
Message 11 of 17
(1,771 Views)
You are expecting 2 pulses per revolution?  What is the highest RPM you expect to measure?
Message 12 of 17
(1,757 Views)
I am using an NPN Sensor mounted near the propeller shaft which will detect a metal edge on the propeller shaft and will give me one pulse per revolution. Can you please rectify my code for measuring RPM.
Message 13 of 17
(1,752 Views)
The maximum RPM I am going to measure will be 4000.
Message 14 of 17
(1,750 Views)
  • What happens when you run your existing code with your hardware?  Does it produce a RPM reading and how does that reading compare to your actual RPM?
  • 4000 RPM with one pulse per rev = 4000 pulses per minute = 66.67 pulses per second = a period of 15mS.  Your bottom loop is running every 50mS.  Much too slow.  This loop needs to run much faster that the pulses are coming in.
Message 15 of 17
(1,742 Views)
Can you please give me a code which can read digital I/O from NI 9426 and measure the RPM.
Message 16 of 17
(1,721 Views)
Anyone please check my VI for RPM measurement.
Message 17 of 17
(1,694 Views)
