08-13-2008 09:48 PM
Hi ,
I am doing same resistance measurements and i need to measure the time as well for every data point. I have tried but have not succeded so far. Does any one know how to do that?
thank you for your time.
Helaka
08-13-2008 10:00 PM
08-14-2008 11:27 AM
Hi Dennis ,
Thank you for your answer. I do know what is the delay time, let say I do 150 measurements at a delay time of 0.35 s, that means that the total time would be 52.5 s ,
but if I measure the time right before and after the measurements it gives me 60.51s . Now my final goal is to fit this data to a given function, if I divide 60.51s with 150 and find dt for every data point the fitting is mush better than if I use dt=0.35s, but I still have problems and I believe that is because the time measured is not the right one. I am a attaching these programs and hope that some one might have any suggestion. I did check keithly manual, it does not seem to be a command that says how to measure the time, or may be I am wrong.
Helaka
08-14-2008 12:43 PM
