08-25-2005 08:03 AM
08-30-2005 02:54 PM
Hello Seth,
Is your application trying to read tags that no longer exist, or might it be attempting to access tags that now have a different name? If you try using a new database, do you see the same problem? Is this a new problem for you or are you only in development of your system?
Kristi H
