how to modify the power meter settings of hp816x by using the s/w drivers"
"In the lamdascan function for HP816X instrument driver how do you set the range mode of the power meter (pwm) channel.It sets itself to 0dbm according to the laser power . I have tried using the setinitialrange subvi and also the setpwm parameter subvi.But the program makes no change but sets the range to 0dbm and setting manual of the pwm after running the program. So you can't measure power beoynd -40dbm."
(2,469 Views)
This question was asked in two previous Discussion Forums.
Here is the link to one of them
How to modify the power meter settings of hp816x by using the s/w drivers
Best Regards,
Ricardo S.
National Instruments.
(2,469 Views)
