how to move *.stp files from Anritsu instrument to my PC using LabVIEW.
Hi Team,
  I am automating the  ANRITSU S362E site master instrument using LabVIEW. I didn't find any Pallets in driver or commands which will move the *.stp file to  my PC. I am communicating the instrument with USB connection. I refereed programming guide of instrument also, Though i didn't find any SCPI commands to move the *stp files to the PC.Is there any way ? to move *.stp files from Anritsu instrument to my PC using LabVIEW.
Raghavendra.
(2,948 Views)
Hi aamancha,
Generally, instruments have instrument-specific commands so any functionality is on the instrument side. Based on page 4-5 of the instrument manual below, it doesn't seem like this instrument has this functionality.
"You can save files to internal memory or to an external USB flash drive"
Site Master S3xxE User Guide
https://dl.cdn-anritsu.com/en-us/test-measurement/files/Manuals/Users-Guide/10580-00252U.pdf
Jiwhan S.
Technical Support Engineer
(2,874 Views)
Thanks Jiwhan,
           I already resolved this issue, by reading the data in ASCII spread sheet string form and removed header. This Result is saved with extension(*.STP) file.  Thank for your efforts on this issue.
Raghavendra
(2,852 Views)
Mark your answer as the solution so it shows as closed.
Tim
GHSP
(2,838 Views)
