how to open a 8.5 file in 8.2?
i got a 8.5 file but my home just have 8.2 labview...
how can i open the file for free?
may anyone can help me to convert to 8.2or 7.1?
Thanks you
Message Edited by dasdsadasdvvvvv on 10-26-2009 09:08 PM
(3,287 Views)
You can't. Post the VI and ask if someone can convert it for you.
(3,286 Views)
You cannot open up a 8.5 VI in 8.2.  Open it up in 8.5 and save it in 8.2 format. Or you can ask some one on this forum to convert it. Sadly i and every one in my office use 8.2 and i encounter similar problems otherwise i wouldve done that for you.
By the way do modify this VI a lot by adding names and changing colours. Ur teacher will be a proud man when he finds an assignment VI, made, converted and distributed from the NI forum. This calculator VI has been roaming all over the forum for all sort of help since yesterday. and too many of your class mates have this VI.
Best of Luck for your assignment.
Regards
Asad Tirmizi
Design Engineer
Institute of Avionics and Aeronautics
" Its never too late to be, what u want to be"
Using LabVIEW 8.2
(3,267 Views)
here is ur vi
but do follow the instructions given by Asad_Tirmizi or else your teacher will.................
hahaha,  i hope you understand
Somil Gautam
Think Weird
(3,263 Views)
Sorry, did not even notice that you had attached the VI. Here it is as 8.2.
(3,259 Views)
Dennis, it looks like the original message was edited to attach the VI after you had posted your message.  You hadn't noticed it because it wasn't there yet. Smiley Very Happy
(3,254 Views)
😄 uve got eagle eyes sir.
Regards
Asad Tirmizi
Design Engineer
Using LabVIEW 8.2
(3,251 Views)
