how to open and read many files from a directory and store contents in 2D array?
I want to make a VI that opens and reads the data from various files contained in a directory (200 files each with 2 columns) and store these in a single 2D array. For file number 1 I want to store the data from both columns in the 2D array, but for files 2 to 200 I only want to store the second column of each file. Can someone please help?
(2,908 Views)
1) Use "File I/O / Advanced File Functions / List Directory". This VI will get you all files that found in folder.
2) In "FOR" loop with auto-indexing read each file by "Read From Spreadsheet File.vi". This vi will get you array of data that founds in file.
3) Build your array.
(2,908 Views)
Hi Nadav,
Thanks for your help. I have followed your instructions but i cannot get it to work. I used the LIST DIRECTORY to list the files in the directory - that works. However, how do I read each of the 200 files using READ FROM SPREADSHEET FILE without me having to manually select each of the 200 files? So, if I use LIST DIRECTORY to list all 200 files in an array, how do I get each of these to open and store the data in a 2D array? Here is what I have done (File called read_files.VI) Could you please help me? Thank you very much in advance.
(2,908 Views)
Hi RVR,
have a look to your "manipulated" vi - maybe it is close to your solution.............
regards
wha
(2,908 Views)
hi
I am having similar problems, do you have this vi for version 6i....thanks
(2,908 Views)
