how to open labview 8.5 exe in labview8.2
hi
          it is possible can i able to open labview 8.5 exe in labview8.2?
(4,281 Views)
Silly question. You can't even open an 8.5 exe in LabVIEW 8.5.
(4,259 Views)
Dennis is right (for this discussion).  An EXE contains the compiled code, it does not contain source.  If I gave you a DLL built in C# how silly would it sound to ask you to open it in Java?  This isn't the exact same because that is two different programming languages but still, when there doesn't exist a decompiler, no source can be pulled from a binary, unless the source was embedded in the EXE which is almost never the case.  Post more details if you can but my suggestion is to contact the original developer and get the source from them.
(4,227 Views)
ha thank you
                    .i have labview 8.5 and labview8.2.i develeped program using LB8.5  than i can  able to open in LB8.2.bacause now i have source code(LB8.5) not EXE.
(4,198 Views)
No, you cannot open LabVIEW 8.5 VIs with LabVIEW 8.2. Do a Save As with 8.5 or post to the Version Conversion board. Since you have both, I don't understand why you simply didn't try it yourself instead of posting the question.
p.s. The typical way to abbreviate LabVIEW is LV and not LB.
(4,186 Views)
k because i am using labview 8.2.i have some doute means than i go and search web get example vi(higher version).but i am not able to use this.that y am asking if have other way can i use that example.
(4,161 Views)
If you don't have 8.5, then I don't understand why you would have said you did in your previous post. If you only have 8.2, then post it for conversion. I already told you to do that and you haven't.
(4,150 Views)
