how to ouput a digital sequence to a single digital port line ?
Dear Ni,
This is Rex, I am kind of new about labview, I am kind of stuck in one problem.
 I am working on daqpad 6016 and trying to output a digital sequence to a single port line. like 11010101 to line1 on port 1
I included my vi and a snapshot of my problem.
Could you help me out?  I am using labview 8.2
Thank you
(2,846 Views)
Sorry for the picture.
(2,843 Views)
Try not to post such large images.
The error means exactly what it says. Your board does not support hardware timed digital I/O so you cannot specify timing. With on-demand, your digital output is software timed so for each bit you want to output, you will need to perform a DAQmx Write set to 1Chan 1Samp.
(2,830 Views)
