how to overwrite a file with "write bmp file .vi"?
I want to save a bmp file with labview 6.0.
I use the composant "write BMP file.vi" and when I want to overwrite a file, an error appears : write new file in write bmp file.
Thanks in advance
(3,237 Views)
Open up the VI and look at the New File function. It has a false constant wired to the overwrite input. Instead of a constant, make it a front panel control. Save it as a different name and in a new location.
(3,237 Views)
Sorry, but I want to overwrite a file (same repertory and same name).
In the "write a bmp file .vi", there is no constant to manage it....
If that can help you, I have put in attach a part of my file...
Best regards
Titia
(3,237 Views)
My LabVIEW 6.1 Write BMP File.vi does. If the attached picture does not match your version of the VI, what version of LabVIEW are you using?
(3,237 Views)
My composant "write a bmp file" has no "refnum" node.
The error I meet is, in french, "erreur 10" puis "Chemin en double"...
My labview 's version is 6.0.
Titia
(3,237 Views)
Maybe there's some sort of language barrier but all I can do is repeat my previous answer. Inside "Write BMP File.vi", you will see the New File function with a false wired to the overwrite input - the area I circled in the picture. I looked at the 6.0.2 version and it's there. Refnum has nothing to do with it.
(3,237 Views)
Thanks a lot for your answer. It works!
I hadn't understood that the "Write in BMP file" composant is a sub VI....
Best regards
Titia
(3,237 Views)
