how to pass address of the pointer array in the API function
Hi.
I want to know how to pass the array pointer address to the CLN in LabVIEW and i'm using the DLL for this API function.
This is my API function in C.
API_function ( Numeric,enum, sizeof(structure), &abInfo[0]);
typedef structure {
unsigned char a[16];
unsigned char b[16];
} mystruct
abInfo is an array of  unsigned char type
i.e unsigned char abInfo[300];
How can i do this?
(3,400 Views)
Initialize a array with the correct type en length and connect this to the input of the interface node.
(3,378 Views)
Hi have created and configured the array to the correct type .But i dn't know how to capture the data from the hard ware card into teh labview arary ie
in my function, one of the parameters is &abInfo[0]
how could i do this?
(3,377 Views)
Can you post a basic VI with the interface node ?
Message Edited by K C on 12-21-2006 01:14 PM
(3,374 Views)
I'm attaching the front panel,Block diagram and CLN configuration of my function
(3,353 Views)
Can you try to connect the array as shown in the picture ?
(3,338 Views)
