how to pass boolean value from one while loop to another while loop
Maybe this is a very simple question for you guys, but I am just wondering how to pass boolean value ( and maybe other data type too ) from one while loop to another while loop.
See the attach file for simple example.
Alvin Chandra
(3,536 Views)
You can do this with help of Local Variables or with messaging techinques Queues,Notifiers..
Silver_Shaper | CLD
(3,534 Views)
You should use a local variable (right click the boolean control: create>variable) and read the help and attend a LabVIEW class.
Christian
(3,532 Views)
Hey Alvin,
I'm not sure how extensive your diagram will look but you should be able to do a simple state machine/diagram if you're trying to keep in sequential.  Just a thought.
(3,525 Views)
