how to perform reset operation after performing one operation??
hello,
i want to know about reset function.
in my system i am dealing with different instrument like power supply ,GPS,GSM...
in my system i have 2 section in 1st section i have set only ON and OFF operation of my devices and in second section i have to deal with Current and Voltages and GSM's task,for that i have put one start switch (from boolian)after giving start 2nd section will start to perform operation until the end and LED of regarding section will be ON,but when i press start switch again then  my 2nd section shoud be reset and from begining it shuld be start to perform operation.
here in attachment i attach my front pannel in that you can see that on start button i have used after pressing it my system shoud be reset that i cant do it.
please let me know what kind of logic i have to use for reset the function.???
thanks in advance.
Message 1 of 36
(4,234 Views)
I would be much easier to understand what you are doing if you could show us some code.
Instead of ordered consecutive "sections", it would probably be much better to implement a state machine, including idle and transition states.
Message 2 of 36
(4,223 Views)
i attach here my all vi.and in this there is start button after pressing start my all funcion shoud be reset.
its ok or i need to explain my problme in more detail.
Message 3 of 36
(4,220 Views)
You only attached the project file, it does not contain any VIs. Just zip up the VIs or create a source distribution, for example.
(according to the diagram image you have now attached to the original post, your diagram is gigantic (look at the vertical scrollbar!).)
Message 4 of 36
(4,204 Views)
Message 5 of 36
(4,194 Views)
hello,
i have use same logic which i attach here,but as my operation of vi is so long i cant stop my runing vi at a time when i press the butten (means i have to wait until all the proccess within loop shoud be finish)  which is shown in front pannel in attachment (stop application).
thats why i m thinking to use stop function(Programming << application << stop)  which is stop all the proccess at a time but i didnt find out proper logic for that.
please suggest me some logic so by using that i can generate one stop button on my front pannel and any user want to stop running vi at any time , they can do it by simply pressing that button.
Message 6 of 36
(4,054 Views)
i dont understand your english, logic or reasoning....but i would make your stop button a switch and a local variable wired to the second loop stop if true and finish your vi with a false reset to your local stop variable. please provide a visual aid to explain your logic?
Message 7 of 36
(4,040 Views)
hii,
in my vi i want to set some function which customer can easily understand,
i want to make one run button ,one stop button
i got success to creat run button by following attached vi in my previous post,now i want to make one stop button by pressing that user can stop running vi at any time.
but the problem is in previous attachment is that i can't stop my vi at any time i have to wait until all operation of while loop shuld be performed.
Message 8 of 36
(4,027 Views)
Ok i got success to halt at any time ....
thank you very much for every one who gave their time ....
Message 9 of 36
(4,021 Views)
can it possible to create pause button in vi,which give simmiler function which is on the top bar menu.
Message 10 of 36
(4,020 Views)
