how to place FP.nativewindow
I just turn on the vi scripting option in LV2018.
But I cannot find FP.NativeWindow in VI property node.
Can you guide me how to place the property in my block diagram?
labmaster.
(4,962 Views)
Version 2018 Saved, open and drag into your VI.
mcduff
(4,942 Views)
Thank you for the reply.
But I figured out the color of property node is different to what I see the forum (see the image).
The property cannot be found in the menu.
Can you guide me what I need to check?
labmaster.
(4,937 Views)
Accepted by topic author labmaster
Maybe I am thinking of the wrong property then.
Look at this link for an explanation of the colors.
The method I posted is a private method, look at this for an explanation.
mcduff
(4,932 Views)
Maybe, the color is not a problem because of normal working.
However, I cannot locate the property in the node by myself. (see my list)
How did you find it?
labmaster.
(4,894 Views)
labmaster.
Look at the second link in the previous post
(4,890 Views)
