how to plot a waveform graph outside for loop?
To make the x axis simple, change the DAQ Assistant to continuous mode and 500 samples. That way each second you will get 500 samples. Then, in the scaling box I mentioned, enter a value of .002. That is equal to your sample time (1/500). Then if you want 60 seconds worth of data, run the for loop 60 times.
I'm sorry I only have time for this quick update and can't look at the other VI right now.
Message 11 of 12
(835 Views)
Thank you Dennis,
it's working perfeclty now..that was a great help from you
Thanks a lot again.. 🙂
9712
Message 12 of 12
(818 Views)
