how to plot acceleromter sensor data from serial port
hello... i have attached the images...i have a problem in plotting accelerometer sensor data...
please help
(3,109 Views)
Without more informaiton I'm going to guess that you have a periodic noise signal added to your accelerometer data.  Best scenario is to fix it at the source (shielding, routing, gounding).  Failing that, maybe try a notch filter to kill the frequency of the noise (60Hz?).
We'll need more information if my guesses we're helpful.  Please post you VI and/or a better screenshot of the data (ALT+PRTSCRN rather than camera) along with details about your setup (hardware, accels, etc. ).
(3,083 Views)
i am interfacing MMA7361 3 axis accelerometr sensor to msp430g2 launchpad...
i am getting the values correct but i am not able to plot the value as a i want...
i will attach my VI shortly...
(3,076 Views)
