11-20-2007 11:13 AM
11-20-2007 12:27 PM
Nobody has ever used this?
11-20-2007 12:39 PM
Where did you get this example. I can't find it listed in the current shipping examples.
Also, posting a small image of a section of a block diagram is not much to work with. You are using local variables and a sequence structure. Neither one is a good sign. If you would simply post the actual VI (and any subVIs), it would be much easier to see what you mean.
