how to plot date and time read from spreadsheet
Dear Friends,
I am saving text. data from a power plant devuces like temperature, flow, control signals etc. where 1st coloum is the date and 2nd is time ..and rest are prodess variable data.
I am reading date and time seprately in a string formet using "Read from spread sheet.vi".
Now I want to plot this process variables in graph or chart, but I didnt found a way, so that the date and time which I am reading form text file will shows on X axis.
please let meknow if there any possiblity to solvce this problem.
Patel
Message 1 of 17
(4,654 Views)
Post your current effort please, also look at examples try the example finder.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 2 of 17
(4,652 Views)
Message 3 of 17
(4,647 Views)
Sample log files would help as well.
Message 4 of 17
(4,643 Views)
I am saving data in a text file ....
I am attaching a copy of text file from where I want to read date and time and want as X axis...
Regard´s,
Patel
Message 5 of 17
(4,635 Views)
Since your data is not equidistant you will have to use a XY Graph. For the interpretation I created a small example, just reading the date/time as well as the first three channels of your data.
You should be able to build up on this.
Christian
Message 6 of 17
(4,614 Views)
Dear Friend,
thank you for your reply.
I tried the concepts which you suggested me in your last reply. But its not working in my case. is it because of Labview version or ...as I am using 8.6,
I am attaching my vi file ..please check and give feedback.
looking forward to your reply.
Kind Regard´s
Patel
Message 7 of 17
(4,608 Views)
The VI I posted before works fine with LabVIEW 8.6 too!
There is no change necessary except that you expand it to read more then the first three channels.
Why did you put a loop arround the whole code? And without any timing inside!
Why did you change the delimiter to "_"? The file you posted uses "\s\s"
Christian
Message 8 of 17
(4,603 Views)
When I am using "\s\s" at that  time its not working. so i replace it with "_".
I got time on X axis ..but in a seconds formate...
as shown in figure,,,attached below.
is there any way to get this seconds in time and date formate?????
Looking forward to your reply
Patel
Message 9 of 17
(4,597 Views)
Your format of \s\s did not work because you did not right click on the constant and select '\' Codes Display.
To format the x axis, right click on the graph and select XScale>Formatting and go to the Display Format tab.
Message 10 of 17
(4,590 Views)
