how to plot different v-I graphs on a same graph
Hi All,
Presently I am using an express xy graph. I need to  get multiple V-I graphs on the same from their respective array points(which would be different for each v-i graph) and with different colours. Also i should be having the provision to change the colour.
(4,063 Views)
Please see the attached example for how to put multiple plots on an XY graph
Cory K
(4,047 Views)
Thanx for your reply..But I forgot to mention earlier that we are using labview 7..And so could not even open the example you have attached with it....
(4,025 Views)
Accepted by topic author saki
You can easily re-create it, as it's a simple VI. You can also look in the Example Finder (Help -> Find Example) on how to use charts and graphs.
(4,006 Views)
