how to plot the histogram with text.file
I have generate some data in the txt. file and want to use these data to plot a histogram.
Can you give me an example how to do it?
(3,413 Views)
Check the attached image.
Joe
(3,412 Views)
I've made a little VI that could help you understand how to plot the histogram of your textfile.
You need first to convert your file into an array of values. I also attached a VI that makes it for you.
Hope this helps !
Julien
(3,412 Views)
quite useful
(3,412 Views)
Hi there,
I wish to access VIs the but when I downloaded it there is some sort of errors, does eriasystemes mind to reupload the vi and text file again?
Appreciate it very much!
(2,790 Views)
