how to pointer array colomn from the result
hello,
I am currently working on project that involves in this picture, i having difficulty in choosing the smallest value
how to choose the smallest value,
if the least value is 1 (brown number), then weight value [2 2] will be the next process,
if the least value is 2 (brown number), then weight value [2 3] will be the next process,
if the least value is 3 (brown number), then weight value [2 5] will be the next process,
and this is my example with the smallest result was 2 and [2 2] will be the next process, how to process the weight but only [2 2] that will be process ?
(3,007 Views)
Hi diikaborg,
You use ArrayMinMax. It gives you the smallest value from an array - and also it's position in the array…
Can you explain your logic here with more details?
Do you mean "smallest" when you write "least"?What is the "brown" number?What have you programmed so far? Do you have any VI to show?All we see is an Excel sheet: do you want to create an Excel macro?
(2,990 Views)
sorry for my bad english.
actually it was a self-organizing map formula, and I'll like to use in Labview, formula above is looking for D1, D1 is neuron index that will be searched for the smallest value.and the result are D1=2 ,D2=5, D3=17 from calculating with formula  .it means the smallest value is 2, "2" from weight [2 2] in file attached.
it mean [2 2] + 0.5 ( [1 1]-[2 2] ) = [1.5 1.5]
and the weight will be  [1.5 2 2 ]
                                          1.5 3 5
Im sorry for my typo, I mean the smallest value , not "least". brown number is the number in excel that colored brown in the result.
and this is my program . I used excel just for explain here
I would appreciate any input/help on solving this
thanks
(2,954 Views)
