how to popup message when user try to select same item form the listbox for more then once
hi,
Please let me know how to display the popup message when user try to select or click the same item from the listbox  for more then once
thanks,
chethan
(2,578 Views)
Cross Post
You said if you don't reply then the problem was solved.  I guess it wasn't.
(2,557 Views)
I'm not entirely clear on your particular configuration. Could you provide more details or some sample code?
(2,504 Views)
