how to prevent popup windows when opening the main.vi with menu in use?
Hi I have a problem with the pop up windows.  I have 3 programs - main, entry and realtest.
Entry and realtest are in main.vi. Entry and realtest are called to open and run by programmatically in main.vi. There's one problem with entry. I cannot understand how it could have happened. There's a menu bar used with 2 items that open up the pop window when selecting one of the items in the menu. I open up entry.vi and it itself opened up with 2 pop-up windows altogether. Of course, I linked the 2 pop up windows to entry by by use of menu. So I have to close the 2 pop up windows and run entry.vi alone. I can open up one of the pop up windows and It worked fine.
However, after I compiled main.vi together with two and tested it. Funny,  after running the main.vi, the entry is also opened. It is correct as I expected it but why do the 2 pop up windows also opened up suddenly too? it looks like the same thing happened during the development time. I never use the menu bar to open them up initally!
So how do I do to prevent the pop up windows when opening entry.vi during the development or run-time environment?
regards,
Clement
(2,483 Views)
And I am using event structure for menu.
regards,
Clement
(2,479 Views)
Hi astroboy,
can you post a simple example VI, just to show the priciple.
Greets, Dave
Greets, Dave
(2,467 Views)
