how to program a simple relay ON/OFF manually?
In your last example you're trying to write to and read from the same lines.  You've set those lines as digital outputs already.  If ou want to read (monitor) the ACTUAL physical changes you'll need to set up 4 digilat INPUTS on different lines and then connect a wire (real wire) between the appropriate lines.  Reading a line this way will not load it down, it will still fire your relay.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 11 of 30
(1,657 Views)
I don't believe this is true. I've done this before with digital I/O and you can do a read on channels you have configured for a write. I'll try to see where this is documented.
Message 12 of 30
(1,647 Views)
I wasn't sure if that would throw an error or not but I wonder if it's actually measuring whether or not the line HAS changed or just that you TOLD it to.  In any case, that's why I suggested that the OP just monitor the lines physically with four dedicated input channels.  I'd be interested in the documentation.  Especiall since a co-worker just stole my USB-6251 so I can't try it out here. Smiley Sad
Message 13 of 30
(1,638 Views)
Here's a KB article but with a link to a private AE domain.
Message 14 of 30
(1,634 Views)
@Dennis,
                So the code I have written should work right??? Or I need to make any changes??? Looks like I have done what its mentioned, but I cannot see any
LEDs glowing...
Now on LabVIEW 10.0 on Win7
Message 15 of 30
(1,624 Views)
@CrackJack wrote:
@Dennis,
LEDs glowing...
Why not just measure the digital outputs with an external DMM or o-scope?  That is the important thing right?  If they're toggling properly, you can trust that the boolean controls are indicating the true state of the physical outputs.  You can add in the extra monitoring functionality later if you want to.
Message 16 of 30
(1,617 Views)
Internal channel access.  Interesting!
Thanks Dennis.
Message 17 of 30
(1,608 Views)
@NIquist wrote:
@CrackJack wrote:
@Dennis,
LEDs glowing...
Yes, I can... but I have nothing connected to the hardware as of now... Hence, wanted to check...
But I think I will bellieve the toggling of LEDs...
Message 18 of 30
(1,597 Views)
@CrackJack wrote:
@Dennis,
LEDs glowing...
Did you add an error indicator inside your loop?
Message 19 of 30
(1,595 Views)
@CrackJack wrote:
@Dennis,
LEDs glowing...
Yes, I did, and no errors are observed....
Message 20 of 30
(1,590 Views)
