how to programatically adjust array of clusters element height
I have an array of clusters and depending on how many samples are being ran, I need to add more rows to the arrays within the cluster. This causes any rows beyond the default of 3 to be cut off. I would like to dynamically adjust the height of the  elements to account for this but I cant figure out how to do it for a cluster.
I found this for an array of strings but the height property doesn't seem to be an option for a cluster.
Any advice would be much appreciated.
(2,648 Views)
Hi DP,
have you tried to set the cluster to "Size to Fit"?
While this may work I strongly suggest not to go this way: it makes a very ugly UI and UX.
I already suggested a listbox approach today here
(2,629 Views)
