how to programmatically change the width of a graph?
How can I programmatically change the width of a Waveform Graph or Waveform Chart? When I create an implicit property node for a graph or chart, it is read-only. Changing the plot bounds worked in earlier versions of LabVIEW, but not anymore.
(4,812 Views)
Accepted by topic author bmihura
It works for me in LV2013 but I'm using the Plot Area : Size : Width property.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(4,788 Views)
NIquist,
You are right, it is "Plot Area", not "Plot Area Bounds" that works. My memory failed me. Thanks!
(4,777 Views)
I use Image Display in vision development. I can only get the property node of a Image Display. How can I get the property node of Plot Area?
(3,523 Views)
