how to programmatically change which VI has focus
i have an application that consists of several interface VIs that are loaded and managed from a master control VI.  often, I loose track of one of my smaller front panels behind a block diagram or other, larger, panel.  is there a way that my master application could bring one of the sub apps to the "front" of the other windows (ie give it the operating system focus)?  the "bring to front" method only seems to work for the entire labview application instance...  is there something similar that works on an individual VI level?
thanks....
(2,754 Views)
The best solution I can think of, is closing and reopening the front panel. It works and It will not affect the execution. But maybe others have more efficient suggestions.
(2,742 Views)
