how to programmatically check the error messages of a broken vi using labview scripting
hi Folks,
I'm basically trying to write some code which checks for broken vis in a folder and show the error in the broken vis. i got the part which detects broken vis but cant get the part which shows the error in the broken vi. is there a way to detect this? greatly appreciate the help.
-S
Message 1 of 13
(6,168 Views)
Message 2 of 13
(6,111 Views)
Out of curiosity, what does the 'Call Dangerously?' parameter do? I like to live dangerously, I can't help but feel like I would need to set it to true in all instances! (Like having a button that says 'Do not push'!!) Smiley LOL
(blog)
Message 3 of 13
(6,102 Views)
Message 4 of 13
(6,094 Views)
i cant seem to find this method for some reason. is there something that needs to be done?
Message 5 of 13
(6,086 Views)
You can just drag the snipet onto a block diagram.
Or add these to LabVIEW.ini:
SuperPrivateScriptingFeatureVisible=True
SuperPrivateSpecialStuff=TRUE
SuperSecretPrivateSpecialStuff=True
Message 6 of 13
(6,064 Views)
BTW the LabVIEW Wiki has been down for some time so I can't look it up, but is there actually a difference in those 3 INI keys?  The only one I know of that actually does something is the SuperSecretPrivateSpecialStuff which enables private methods, properties, and adds a few new events in the event structure.
Message 7 of 13
(6,058 Views)
I think some of them were for earlier versions of LV.  I haven't really kept track of them, I just keep them all turned on (plus some others).
Message 8 of 13
(6,053 Views)
Here's your unpushable boolean:
Message 9 of 13
(6,045 Views)
Paul,
that worked. thanks a lot. have a question though. is this invoke node part of scripting? I see that one of the variables had scripting in it.
also, i need to mass deploy this on many machines and so would have to add these variables on the ini files of all the machines ( which can be done) . but wanted to know if there was any other way to do this?
Message 10 of 13
(6,039 Views)
