how to programmatically configure USB devices, So that each time a new device is used on the same computer it will work.
Message 1 of 11
(5,703 Views)
Without more detail (what devices, what MFG, etc ) I can only guess but,  I think this might be what you are looking for
Message 2 of 11
(5,681 Views)
Jeff,
Sorry for the lack of details.
But what I would like, is a way to automaticlly reconfigure NI's "USB-6259"
Currently, when a USB-6259 is connected to my computer, MAX will asign a Device#.
each time a different USB-6259 is connected to the same computer, the Device# is incremented.
Which causes my VI not to work, unless I physically go into MAX and reconfigure the Device.
So I'm hoping for a way to have labview automaticlly configure, each time I change my USB-6259.
Thank you
Message 3 of 11
(5,671 Views)
Have you tried renaming the device in MAX? I generally name my device. If I need to delete it or change it, I go into MAX and delete the device and rename the new one. The program refers to the device name and no changes to the program s needed.
Message 4 of 11
(5,662 Views)
Check the link in my first resonse----  You might be pleasantly rewarded Smiley Wink  that API can reassign aliases (according to prophecy)
Hence my tag on the site "TryThis"  I haven't yetSmiley Surprised and would like some feedback. Smiley Very Happy
Message 5 of 11
(5,659 Views)
Here is how I solved this issue for myDAQ, basically this function will generate the physical channel string for the first availible myDAQ (you can change this to other devices).
https://decibel.ni.com/content/docs/DOC-17682
Message 6 of 11
(5,471 Views)
I have the same issue, the problem with the API is that it can only reassign an alias to a name not already being used in the system.
So if my newly connectly USB device is shown as 'Dev2' but I want it to be called 'Dev1' it doesn't work as you cant rename it to an existing name (the disconnected USB device). So frustrating!
Has anyone managed a workaround for this yet?
John Mc
Windows 7. LabVIEW 2011.
Message 8 of 11
(5,369 Views)
19,
Not yet,  although there have been Idea Exchange posts related to this.  For now you still need to use MAX>>Tools>NI VISA> VISA Options to manage Aliases for non connected USB Devices.  Just clear the old Alias (And Save) then the old Alias can be assigned to the new device.
When you see this screen you are in business
Message 9 of 11
(5,349 Views)
Hi Jeff,
As the customer I'm currently working for wanted the system to be as automated as possible I came up with this Community Example:
https://decibel.ni.com/content/docs/DOC-26658
As it is only the revision there is plenty of room for improves, please comment on the Community post with ideas. A link to the Idea Exchange post relating to this subject would be helpful too!
19jmc.
Message 10 of 11
(5,319 Views)
