how to put a value of combobox in the clause where
i want to put the value of item selected in the combobox  in the clause where .help please
(2,528 Views)
Hi bibou,
I'm not sure exactly what you are getting at. You want to take a value from a combo box and put it where?
Ryan
(2,488 Views)
You can just use the Value property in a property node of a Combo Box and that will give you the currently selected combo box item. You could then concatenate that into your Where clause.
(2,478 Views)
