In your System sub-palette, you should find "Engine Launch.vi" and "Engine Shutdown.vi" (I am using LV DSC 6.1 so it might be a little different than yours).
Also, there is a good little utility VI in the shipped examples (I found it with the "Tank System.vi"), but the VI is called "Launch Tag Engine.vi", found in ".\examples\lvdsc\_common\Tag Engine.llb". This utility will stop AND start the tag engine, but only if the SCF file has changed.
