how to read analog input channels from DAQ
Iam using DAQ 6071E.I configured 32 channels for analog input.I want to read these analog inputs from all the channels at a time.I have seen in example VIs but they are for single channel at a time.any examples are welcome.
(2,590 Views)
Hi you have to look in the exemples :
C:\Program Files\National Instruments\LabVIEW 7.0\examples\daq\anlogin.llb\Cont Acq&Graph (buffered).vi
Here on the front panel, you can configure the number of channels you want
depending on the way you want to make your acquisition (internal / external clock, triggered etc ) you may want to chose another vi in the same llb.
Cheers
Doc-Doc
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
(2,585 Views)
