how to read analogue input signal in NI 9201 module using lab view
hi all
iam using Crio 9012 module for real time controller
nd iam using NI-9201 for input and NI9263 for output
i have configures cRIO 9012 on my Pc
but how i will take analog input using NI-9201 module
thanks
tc
(3,815 Views)
Accepted by topic author Nabeloabbasi
I would recommend taking a look at the following examples in the LabVIEW Example Finder.  If you go to help-->Find Examples, you will see this window.  Just search for 9201 and you'll see these 2 examples:
Hope this helps!
Tejinder Gill
Visit ni.com/gettingstarted for step-by-step help in setting up your system.
(3,792 Views)
