how to read channel for channel and appended data for appended data?
Good day,
I wrote a little program that saves blocks of data after a trigger to a file, it will append these blocks off data as much times as you set it. Each appended data block has a time stamp and a signal path and burst number as a header.
I use the storage way to save it to TDM format. This all seems to work nicelly.
Now is my question:
Afterwards i want to read each block or burst seperatelly. How can I do this. I can't seem to find an easy way to read just one data block in the file.
best regards
Joost van Heijenoort
Ursa Minor Space and Navigation
(2,503 Views)
allready found out that I have to save it in unique channel names...
this helps..
best regards
Joost
(2,478 Views)
