how to read current of agilent E3631A power supply in Labview?
I have two agilent E3631A Power supply,and I have downloaded the drivers from NI.com,When I
measure the output current of E3631A,it often report error(picture 1),and i send the SCPI
command to the E3631A,it often report timeout error(picture 2).I don not know how to fix it?who can
help me!Thank you very much.
(5,103 Views)
Your command is not correct. You should look at the command in the read measurement function or look it up in the manual. It is :MEAS:CURR? P6V;. Also, you say you have the E3631A but the functions on the LabVIEW diagram are all for HP3632A. You have to use the instrument specific functions when provided.
(5,097 Views)
